It recently occurred to me that given that the vast majority of chlorine loss happens during the day that it probably makes sense to run the SWG only during the day as well.
Say you have a SWG and variable speed pump that runs 24/7. I think the general recommendation is to run the SWG 24/7 as well. That might be easier to configure since you won’t need a timer for the SWG, but I am thinking that it makes more sense to just run the SWG during daylight hours.
These numbers are oversimplified to make my point clear, but assume you have a pool with a FC loss of 4ppm per day. Obviously you would set your SWG to produce enough chorine gas to add 4ppm of chlorine to your water each day as well. If the SWG is configured to run 24/7 then it would produce 2ppm from 8am to 8pm and 2ppm from 8pm to 8am. However, if we look at how chlorine is used in the pool, nearly that entire 4ppm loss will happen from 8am to 8pm, primarily due to the sun and swimmers. Also assume this pool has a CYA level of 80ppm. According to the chart the target FC level is 6ppm and the minimum level is 4ppm.
Say I wake up at 8am and test the water in this pool and discover that the FC level is perfect at 6ppm. However, by 8pm the pool will have experienced the full 4ppm daily chlorine loss, but the SWG will have only generated 2ppm of chlorine, so now the FC level in the pool is 4ppm and just barely at the minimum level. If it was a particularly sunny day or there were a lot of swimmers it might even dip below the minimum level. Overnight the SWG will continue to run and produce another 2ppm, bringing it back up to 6ppm for my test the next morning at 8am. I’m happy logging 6ppm tests at 8AM every day with no idea that my chlorine is actually dipping so low every afternoon.
On the other hand, say the SWG is configured to run only from 8am to 8pm and to generate the full 4ppm of chlorine during those 12 hours. Again I do a test at 8am and get a result of 6ppm of FC. Again, by 8pm the pool will have experienced the full 4ppm daily chlorine loss, but this time the SWG will also have generated 4ppm of chlorine, keeping the FC level at 6ppm and well within the safe range. There should be no chlorine loss overnight and no additional chlorine generation because the SWG will be off overnight, so the next morning at 8am when I test I will still see a level of 6ppm of FC.
I realize that to some extent this is kind of splitting hairs and a pool will run fine and be successful with the SWG running 24/7... there are already lots of people who run their pools that way without issue. But the is the deep end forum and it seems to me that for the cost of a timer it would be better to run the SWG during daylight hours which should keep the FC levels very consistent all of the time. No more swings up and down or danger of getting close to or even below the minimum level at the end of the day.
Am I missing something here or does this make sense to you guys too?
