RS485 Setup basics with Pi and Building Automation Hat
carracc
5
castaic, ca
Hayward Aqua Rite (T-9)
Hey all sorry for the basic question. I am trying to get my hayward tristar vs 950 pump connected to my nixie standalone system via rs485 connection via building automation hat on a raspberry pi. Any help would be greatly appreciated!
I am directly wiring the 3 wires from pump (A,B, and Ground) directly to the Building auto Card rs485 port. I have set jumpers all down on pump and believe all connections are clean and secure.
I setup my building automation hat to have:
  • jumpers to enable the rs485 port (both rx and tx),
  • sent command to release control of the rs485 from the building automation card controller.
    • ~$ megabas [0] rs485wr 0 0 0 0 0
I then try to setup in REM and Nixie
  • Enabled rs485 in REM like attached photo
  • I try to enable port in Nixie but I get the error in the second photo
You are swimming in the deep end of DIY automation...of which there are few here...
Maybe a bump will help...
Road Trip Dog GIF by Tomas Brunsdon
You should only use 2 wires for the RS-485. A and B. Also try reversing them.
In your Raspi-config. Make sure I2C is enabled, Serial port is enabled, and SPI is disabled.
