The amount of stabilizer (CYA of 80) is proportionate to the elevated FC level, so you are fine. Even if you were performing a SLAM at a very high FC level, the robot should fine, although in that case I might rinse it off afterwards with fresh water just for peace of mind.
The spec from Maytronics is a maximum chlorine level of 4ppm, but that does not take into account CYA level. I assume that if it's safe to swim in the pool, it's safe to run the robot in it.
