My Intex Krystal Clear SWG 8100 is working intermittently and not at all the last two days. I've already posted about that issue and gotten a multitude of great suggestions and advice and have tried all of them. Thank you!!
The weather and water remain pretty cool, and I've read several threads and a gentleman mentioned to me that water temp could be a possible problem causing the "Low Salt" and intermittentcy. My plan is to wait til the ambient and water temp raise and test it again. My hope is that as the temperatures warms, the SWG starts working properly.
I understand the apparent reality of a short lifespan for Intex SWGs, but is that even remotely possible that temperature is the problem? It worked less than a full season whereas my last Intex lasted over four.
In the interim, and as I decide which and when on the new SWG, I am using bleach & the Pool Math link to sanitize. I read the relevant sections on chemistry, using bleach, Pool Math...and have started that tonight. In my reading, I came across a process acronymed as BBB being used in combination with SWG with apparently good results.
What is BBB?
The bleach was approx $3/gal at Aldi and I had to add 62oz (~$1.50 worth of bleach, FC was at 0). I don't understand everything on the process of using bleach ongoingly, but at that rate, plus a test kit, and whatever else, if my calculations are correct, that is MORE cost and labor per swim season than purchasing another Intex SWG at $139 on Amazon.
What am I missing??
Last question... Has anyone used the MegaChlor Drape Over SWG in an AGP with any success? If so, what was involved and how long has it lasted for you?
https://www.amazon.com/s/ref=nb_sb_...&sprefix=megachlor,aps,171&crid=29PFBO03A5IKM
Thanks mucho bunches for any info, y'all.
What is BBB?
What am I missing??
