Repurpose that puck bucket?
You can use the tabs, and they will increase the CYA, but it won't be fast. Today feels like one hot & muggy TX day. It won't be long before your SWG needs the CYA of 70. So you might add stabilizer for a CYA goal of at least 50 then use pucks for a couple weeks and see how close you get to 70.
No - do not put stabilizer in the chlorine feeder. It is made specifically for chlorine tablets and you should never cross contaminate with ANY other chemicals.
To most of us, a "puck bucket" is the bucket the pucks came in when you bought them.
Reactions: Rich807 and Newdude
n case I wasn't clear, by puck bucket I mean the now unused tablet feeder at the equipment pad.
Ahhhh, now I see. Not real sure if there is a mechanical reason that would be a negative, but for the simple reason the granules would just sit in there for up to a week I wouldn't' do it. I'd just use the reliable sock method and be done with it in about 30 minutes.
