I moved into a home with a new to me pool very recently. I've taken over the testing and chemistry in the last few weeks and am getting the hang of things. The pool has an old Astral E35 SWG (control box has 5 leds not an LCD like the pics I find online) system with a series 9 chlorinator. Long story short I'm not getting any chlorine output from the system and I've been maintaining the pool with liquid chlorine. Both the control box and cell are dated summer of 2017. I believe I need a new system.
The pool guy that's been helping me with equipment questions is offering to install a Jandy Tru Clear system. Based on my research here I believe that to be criminally undersized for my pool. Right now my pool is consuming about 2.5-3ppm of chlorine a day. It's 35k gallons and gets full sun. I believe the bigger Jandy AquaPure is probably also undersized.
I have a very old Jandy RS automation system so I plan to run the SWG system in isolation just wired into the single speed pump. This is how the current Astral system is set up.
The pool guy also suggested a pentair IC system which seems like it's much more expensive than the comparably sized circupool rj system I see talked about in these forums.
He's adamant that I don't need a system rated for 45k or 60k gallons but I believe in the TFP method of oversizing this component. If I'm going to use a SWG I don't want to have to be dosing a gallon of chlorine a day also...
I'm honestly leaning towards CircuPool RJ60 but it gives me a bit of hesitation that it isn't from one of the "big three" pool brands. That seems to be a common product line on the forums, but what am I not considering by going away from jandy/pentair/hayword.
In terms of purchasing from an online retailer like discount salt or the manufacturer what are some things I could consider? The price difference is relatively close right now.
