Replacing PVC Plumbing, any tips?
Thurston
0
183
RI
One of the inlet valve handles is broken and sharp, the plumbing is kind of sticks out more than it needs to, and now I have a suction side leak that I can't track down. I'm going to replace it all this Spring.
I'm probably change the paths of the PVC a little, any tips or stuff I shouldn't do?
Use High temp unions on your pump
Use Jandy neverlube valves on everything coming and going to the pool
Use Rain and shine PVC glue and check all your pipe fitting to make sure they are schedule 40 >>>> NOT DWV fitting.. :)
