I've got a 9500gal pebbletech pool. The main pump that runs it is a 1.5hp Hayward single speed going through a Hayward 60 DE filter. All of that is fine for now.
The pool also has a negative edge, actually 2 negative edges split in the middle by a wall with a single 36" sheer descent waterfall. The water spills over into two separate basins, each basin has two drains at the bottom, all (4) come together underground and feed the pump. There is also a tube that joins the basins and keeps them even. The current pump is a 1hp Hayward single speed with a diverter valve that sends some water to the waterfall and the "extra" water back to one of the basins. There is no filtration for this part of the pool (negative edge/waterfall) as a result, I get tons of palm debris in the filter basket (it fills almost daily) and the sheer descent receives a slurry which constantly clogs it. During the summer months, I can clear clogs in the waterfall by standing in the pool with a bread knife carefully inserted into the slit. In the winter, it's too cold to do this and it just clogs up badly. I've decided to add a filter to this circuit, it doesn't need to clean the pool since I've got the DE filter and main pump for that, it just needs to keep the waterfall from constantly clogging. The plumbing is kind of tight and since it's going to be a hassle anyway, I figure that this would probably be a great time to swap out the pump for a variable. An additional factor is that the current pump is very large and I've got a smallish concrete bunker in which to fit the required equipment.
Questions:
1. What kind of filter would be best? The main DE filter does a great job, so I don't really need additional cleaning capacity, I just need to keep the waterfall from clogging. I'd prefer simple maintenance here, I was thinking about a smallish cartridge filter or one of those inline Pentair Energy filters, although it sounds like they may be mostly for vacuuming. Advice? Part numbers?
2. Which variable pump? The existing pump is only 1hp and half of the flow gets bypassed back to the basin anyway. I was thinking the little 1.5hp pentair or jacuzzi 150. The waterfall only needs about 30gpm according to Pentair.
3. If I'm going with the variable can I lose the 3-way valve and return circuit for water to bypass the waterfall? I'd rather just slow the pump than move extra water around. If I can stop using the bypass circuit is there a way to plug it at both ends and treat it with something to prevent it from becoming a mold-farm? Like maybe pour in a bottle of vodka and cap the ends?
cheers,
c
Questions:
cheers,
c
