Hello Everyone
I'm in north texas and had some freeze damage. As a result I'd like to change out all the pool plumbing since I have some cracked valves and broken check valve. I'm trying to get input on the best way to assemble the new plumbing. My plan is to allow a longer length of straight pipe to the pump and also a straighter route from the pump to the filter. Also I plan to make a more direct route from the filter (see image 2). Does this seem like a good plan?
A couple of other questions. Should I use 45 degree fittings for a smoother transition? If so which areas should have 45 degree? Lastly can I just use a check valve at the pump?
Thanks for any help!
