I have an old Hayward sight glass with the 4 screws holding it together, and the glass (plastic) is so discolored I have a hard time telling when the water is running clear during a backwash.
Two questions:
a) It looks like to replace it I have to cut the PVC and replumb that part of the system to cement the new sight glass assembly in. It looks to me like cutting and installing a replacement is going to be very tricky, given you have to cement both ends at the same time. Is this a DIY job or better to hire someone who is adept at working with PVC?
b) Given a) above, why on earth does this assembly include a screw-in glass piece, as if you could replace just the glass? You can't as far as I can see. You have to replace the whole thing unless there is a way to install it with a compression couplings (I don't have room from that in my plumbing setup),
Two questions:
