- Mar 5, 2025
- 53
- Plaster
- CircuPool RJ-45
Hi all, looking for some advice on what to purchase for my pool. I for sure need a new SWC, however just replacing the whole unit is an option as well. New variable speed pump is also something I would like to get. I think my filter setup should be fine, unless anyone thinks otherwise.
Current setup (21500 SWG Gunite pool)
Pump - Century USQ1152 (1-1/2HP)
Filter - Hayward StarClearPlus (c1200)
SWG - CircuPool SJ-40 (Works, but the cell is beat up)
Booster Pump - Century Centurion (3/4 HP)
Intermatic Timer
Pipes per the blueprint for the pool (which is cool that I have) shows a 2" suction pipe, and 1 1/2 outlet jets (3)
At a minimum, I will be getting a new SWC, and replacing the pump with a variable speed pump.
I'm quite handy, having replaced the electrical in the house to code, so I will opt to install myself. It doesn't look too difficult to do at all, just some PVC work and light wiring. I understand that this may cause me to not have a warranty for the pump, so that's a consideration.
Budgetwise, I am aiming for around ~5000.
Thoughts/advice on what I should be looking at?
Intermatic Timer
