Replacing Infloor Pool Cleaner Pump Motor
Even if you hear nothing, there are other diagnostics you should check.
- Make sure the motor is getting power. Measure at the motor terminals
- Check the centrifugal switch at the back of the motor for corrosion. The contacts can become dirty and prevent starting.
