Replacing Diving board anchor bolts - Are SS wedge bolts a good option?
jblizzle
43,238
BEWARE: stainless steel hardware is often fairly weak ... even less than typical Grade 5 hardware. So there very well was likely a reason that the old hardware was not stainless steel.
mikeingeorgia
Active member
Jul 3, 2015
42
Atlanta
That's a good point. Maybe it would be better to use galvanized, and cover the bolts with grease after?
CJadamec
2,390
Quaker Hill, CT
A shot of rusty metal primer would offer better corrosion protection than covering them in dielectric grease. Or a layer of nickel anti-seize compound would be a good choice.
Dielectric grease in that application might actually increase corrosion by trapping moisture against the steel.
mikeingeorgia
Active member
Jul 3, 2015
42
Atlanta
Gotcha. Thanks
