I currently have a Hayward Super Star Clear C4000. I can't find specs on it, but would assume the naming conventions hold true and it is 400sq ft. The alternative/newer replacement for that filter is the
Hayward Swimclear Cartridge Filter 425 sqft at $1,179. Really do not want to spend that kind of money!
Is there a better alternative? What if I went with a used Hayward C5025 525sq ft. Does the size matter in regards to pressures? Pool operations?
A picture of the used one in question is attached. Other than checking things like threads and if it leaks, what should I check? It's obviously not currently hooked up, so can't put it under pressure.
