Hello,
The pool is 9 years old and has split at the very bottom about 1/4 up the wall; just below the skimmer. The liner is still intact holding water.
The plan is to entirely cut out the bad section of wall and bolt in a new piece of wall I got from my pool supplier. This is last ditch effort to save the pool.
The problem is the new piece of wall is 52" and my existing wall is 48" Once I trim that wall height down to 48" I'm going to lose one of the factory rolled edges of the wall.
I'm debating if I should place the cut side down at the bottom inside the track along the ground or put it at that top and cover the sharp edge with multiple layers of duct tape to protect the liner when hanging? (overlap type)
I guess the main question is; where would you think placing the remaining rolled edge the most important, top or bottom?
