I have an absolutely ancient board that appears to have finally given up. It is a Hayward Goldline board that was white-labelled as Mineral Springs probably 15 years ago. As you can see in the picture, it looks like part of the board fried. I'd replaced the resistor (or capacitor or whatever that is) about 1.5 years ago after the old one cracked and died, but I don't recall whether the discoloration on the board was so severe then or not. Either way, it isn't working and I get the PCB error so I believe it is time to replace it but want to make sure I get the right replacement. My cell is a T-Cell-15-SWP. Can someone recommend the right replacement? I don't want to pay the pool company $225/hour to tell me I have bad board, then another $225/hour to unscrew some screws, pull and replace some wires then turn it back on when that is all that is required (right?). Is there anything else you'd need to know (22k gallon gunite IG, heater attached but not running). Thanks in advance. Charlie
