Replacement Inlet/Syphon tube - Intellichem tank
mdbrown
27
Sacramento, CA
Does anyone have a part number for the tube that goes down into the tank and syphons up acid/chlorine on the 3.5 gallon tanks? The parts diagram in the manual doesn't list it.
Not talking about the pump tubes that get replaced annually. This is the long tube inside the tank with the red thingy at the bottom.
Thanks for your help!
I believe you are looking for Pentair Chemical Tubing Kit 522446...
No, turns out there’s no part for this. Pentair said parts inside the tank are not available as spares. So instead of being able to buy a $4 part, one has to replace the whole tank for several hundred. Needless to say, I figured out a way to jimmy rig it.
  • Wow
Reactions: PoolStored
