I have a 7 year old Hayward Tristar 2HP pump that is probably going to die in the next year or two (it is making that whiny sound that indicates bad bearings I think). When it dies I would like to replace it with a pump that is quieter and has less vibration. Everyone recommends a variable speed pump, but because I have a floor cleaning system that relies on a certain amount of pressure I have a few questions. I also have a rooftop solar system that needs to pump the water up about 25 feet.
Current pump: https://www.amazon.com/Hayward-SP3220EE-TriStar-Energy-Efficient/dp/B002GP5WBY/ref=sr_1_1?ie=UTF8&qid=1496523082&sr=8-1&keywords=hayward+tristar+2hp
Floor Cleaner: http://www.kynimagine.com/cleaner.pdf
Questions:
1. Would a new identical Hayward Tristar replacement pump be quieter? Or would it be about the same as the one I have now?
2. Is it a good idea to put a vibration pad between the pump and the concrete slab in order to reduce the noise and vibration?
3. If I get a variable speed pump and just dial up the speed until the pressure is about the same as it is now (~30psi), would the floor cleaning system work just like it does now? Or is there something more than pressure to consider with the cleaning jets?
4. What is a good pump brand to install in this situation?
Thanks for any help, not many people seem to have the floor cleaners around here so it's hard for me to trust the advice I've gotten so far.
Questions:
