So I got my box of replacement jet parts and filters. I ordered FC-0303 filters that measured the same length as the old filters that came in the tub, 8.5” long. What they sent me is P5CH-203A filters. While it says they replace the FC-0303 right on the label of these filters, these P5CH-23A filters are only 7”, so they are an inch and a half shorter. They are the same diameter however.
Are these ok to use? I’m worried they aren’t going to flow properly and cause flow errors?? I ordered six of these things, the tub takes 3 and that gives me set to swap between cleanings.
I’m just not sure if that 1.5” is enough of a difference that it matters even though the label says it’s a direct replacement.
Thanks in advance!
Thanks in advance!
