Replaced a century spa pump in a super pump 2600. On one side at the bottom corner I have a leak. When I pull the motor back out what should I be looking for? During the replacement I used a go kit to replace all of the seals/gaskets. There was one that was not present when I removed the pump and it seemed too big to use anywhere. I assume it's not the problem since it was there when I pulled out the old one.
Go kit:
Housing gasket?
Leaking from here:
Go kit:
Housing gasket?
Leaking from here:
