Spa air blower stopped working. Assumed old one dead and it gave me reason to replace it anyway. Purchased and DIY installed. Old: Model 1-516-03 1.5 HP 240v 4a 60hz. New: Silencer 1.5 HP 240v 3.8a. Installed a 240v toggle switch on blower. Blower Connected to a Lens Gordon 240v relay that’s connected to a Lens Gordon air switch.
new blower works for 3-5 minutes and stops. I turn it off at blower switch. Come back after a few hours and turn back on and it works for another 3-5 minutes and stops. rinse and repeat. Notice also the water back flow preventer is bobbing up and down and making noise. Old one didn’t have that so I don’t know if that’s normal.
Other symptoms - I’ve had issues with the air switch not working right. I’ve plugged directly to it and bypassed the line to the spa. It switches once but subsequent pushes of the button won’t work.
Questions:
- Is it possible my relay is going bad?
- Is it possible that even if I used the same specs on the blower, that it’s too powerful?
- is the noise from the back flow preventer normal?
Questions:
