Replaced Jandy VSP motor with non-VSP motor and now status says ePump offline and aquapure won't turn on.
jb_sfl
0
Jan 5, 2015
46
Wellington, FL
Replaced Jandy VSP motor with non-VSP motor and now status says ePump offline and aquapure won't turn on. The pump is moving water fine but the aquapure won't turn on because it still thinks there is an ePump installed and that it is offline. I originally took out a non-VSP pump and installed the VSP pump and remeber there was some settings in the iAuqualink that I had to change, and install the controller cable, but I don't know how to set it back now that there is no VSP installed on the system.
Thanks!
I just figured it out, go to menu, system setup, VSP setup, click on Application column where epump was, and change that to not installed.
The offline epump message disappeared from status and now the aquapure is working.
If anyone ever does this don't forget that step.
