https://www.amazon.com/Polycarbonate-Rigid-Round-Tube-Clear/dp/B0BLB2HXYT
Style: 2-3/8" ID x 2-1/2" OD
Brand Plastic-Craft
Material Polycarbonate
Color Clear
Product Dimensions 12"L x 2.5"W
Manufacturer Plastic-Craft
What's more, we have the capability to cut any piece you order to size. Need your plastic welded or machined?. We have both the facilities and the expertise. Looking for Plasti or Rubber Dip?. Feel free to give us a call.
www.ebay.com
Shop our clear tube option with this polycarbonate clear round tube. Lightweight and durable, it's perfect for various applications requiring transparency.
plastic-craft.com
Diameters: Required
2.375" (2-3/8") ID | 2.5" (2-1/2") OD
These polycarbonate tubes are perfect for a variety of applications when light weight, high impact resistance, and good optical clarity.
They are electrically non-conductive.
Compared to acrylic, polycarbonate is stronger and will hold up longer to extreme temperature.
Our polycarbonate tubes are easy to cut, machine, glue, and shape as desired.
These polycarbonate tubes can be used in crafting, hobbies, product displays, advertising, signs, and much more.
Exceptionally high-impact strength over a wide range of temperatures
200x stronger than glass and 25x stronger than acrylic
Good optical clarity (88% light transmittance)
Higher chemical resistance than acrylic
Excellent dimensional stability
