Hi all, we had a huge amount of rain (3" within 20 minutes or so) flood our property a couple of weeks ago and I want to try getting the pool back into shape.
Our liner is pulling away from the wall a bit, and the pool is filled with dark brown water which prevents us from seeing the bottom. We had a good 1-2 inches of mud (including water) in our basement so I can only assume there's a bunch of mud sitting at the bottom as well. My question is: is it possible to re-attach the liner? Step 1 would obviously be to drain the gross brown water, but should I use the pole vacuum and vacuum it to waste rather than use the pool's floor drain? Once it's drained, is it possible to re-attach/re-seat the liner?
The local pool store wanted almost $100 just to come and "look at it"!
Thanks a bunch!
Thanks a bunch!
