Hi,
I am trying to figure out the pump I should choose to replace mine.
I have a above ground 19000 Gallons. I have calculated a 40 GPM.
My sand filter can handle 50 GPM.
My big question mark is about the heal loss of my installation.
I have come up with a number that seems to be outranging : 100 foot head with 80 feet 1 1/2 pipes ten elbow, 1 valve 1 T.
Ten 90 degrees elbow is pretty common and this alone is 70 foot head. Right?
Is there something I am doing wrong? I am following numbers found online.
Which confuse me because specs of pump usually don’t go that high regarding the foot head.
Any recommendation on pump specs would be helpful or thought on foot head calculation.
Thank you
Thank you
