Hi all,
I've just finished a SLAM after a little algae outbreak. I had a solar cover on the pool when the algae attacked and I took it off and rolled it up onto a holder during the SLAM process. I'm just wondering at what point I should put the cover back on given that it could potentially still have some algae rolled up in it (I'm assuming). Do you think I should put it back in now and continue the SLAM for another day or two to kill whatever is on it, or do you think it will get clean enough if I throw it back on with lower chlorine levels as long as they stay at a suitable range or maybe throw it back on now and just let the chlorine ride down to normal levels?
I should probably mention that I had to slam after jacking my CYA up to 80, so the chlorine level is pretty high - 31+ PPM.
