Greetings, I have a 15x25(ish) in-ground plaster pool at about 12K. Needs major updating. First installed in 1975. Long Island NY.
Replacing two floor inlets (black poly pipe that leaks under the brick and flagstone deck) as well as eliminating the main drain for the same reason.
in need of new pump possibly (I rebuilt the Superpump .75 hp last season). Hayward sand filter ok. Sta-rite NG maxi therm is 20? years old. Hayward Goldline SWG need new t-cell and a few other components. Stainless steel skimmer needs replacement as well. It's a laundry list for sure.
Recommendations needed and Questions galore.
I'm eliminating the main drain as i can't tunnel under the pool so I will put in 2 new skimmers to replace the one old skimmer. I familiar with Hayward but if anyone has a better suggestion please let me know. I'm thinking 2" lines with lower equalizer ports. I know that's additional drilling but it's a safety net if the water level drops, yes?
What heater would you suggest? I think I should stay with NG and not heat pump given my location. Thoughts? What brand? Electric rates are crazy high in the area.
I can stay with my old reliable superpump but don't mind upgrading to a VS. What brand? What HP?
I have an older Hayward Goldline SWG that needs a new t-cell. should I just buy a newer model?
I know I will have a host of other questions coming up, but any input on the aforementioned is greatly appreciated.
