- May 7, 2021
- 161
- Plaster
- Pentair Intellichlor IC-60
This is our pool's first winter and we're running the bubblers with freeze protection. The bubblers can be a little noisy when they occasionally run for several hours overnight. I would like to partially close either the flow into or out of the Pentair single speed pump using the ball valves to lessen the bubble/noise effect. Which valve would be the appropriate valve to restrict the flow? How much can it be restricted before it comes a risk to the pump? Thanks.
