I'm cleaning up a 30,000 gallon outdoor pool in MA that sat open to leaves and detritus for around two years. So far, we've have:
Now, the pool water is blue, but quite hazy. We'll switch to bleach one the cal hypo runs out, and start a SLAM. I'm hoping that the haze will dissipate both from clearing out any algae and stopping cal hypo use.
Is there anything else we should be doing?
- Replaced the seized pump motor
- Replaced the the pump seals
- Replaced the cracked valve innards
- Replaced leaky glued hard pipe between the pump and filter with new hard pipe and union fittings.
- Scooped and vacuumed out a thick layer of leaf and algae muck
- Brushed regularly
- Taken out the railings and ladders to be scrubbed separately
- Brought the chemistry to:
- Alkalinity: 50ppm
- pH: 7.2
- Calcium: 275ppm (probably will level out above 300ppm after my final addition today.)
- CYA: 50ppm
- Chlorine: shocking 1x/day to 20ppm with cal hypo, losing about 5ppm per day now. No CC registering at the moment. We're about to use up our 50lb bucket.
