I had a Pentair VS pump installed and the installer programmed it. It would run my Navigator pool cleaning vacuum (We just call him Bob) perfectly at 2500 RPM. When we wanted to use the jacuzzi, I would simply hit the #4 and the speed would increase to 3500 RPM for the jacuzzi. I was happy at the time.
Then we installed the pool solar at the same time we installed solar on our home. The Pentair pump connected to the Pentair Solar Touch control unit. The installer programmed the crud out of it, it starts at 1800 RPM for a prime then goes to 3600 RPM which pushed the air out of the rooftop solar (makes rad bubbles in the pool though!) and then goes to a set speed. That seems good, but he did these programs on every program level. Now I can only clean my pool manually because the pump has so many programs that it can be running at 2500 RPM and the next minute it goes up to 3600 RPM, then switch to 1800 RPM etc. The programs jump all over the place!!
At this point, I am not asking how to fix the Pentair pump/Solar Touch combo programming as I am putting that on the installer. However I would like to know what settings to have him program, and advice I have received has added to my quandary. The solar touch supposedly blocks off pumping water up to the roof panels when it is not needed (not enough sun). So I would imagine that a good cleaning speed for Bob would be sufficient. How about when the sun is out and the valve to the roof is open? I've been told that the flow should be slow so it can be heated by the solar but have also been told that a slow flow wont allow the water to be pushed vertically up a pipe to the roof of my patio, which also makes sense.
I would really appreciate any recommendations and or advice you can give.
Pool cleaning RPM for Bob?
Pool cleaning RPM for Bob with solar activated?
RPM for solar if Bob is scheduled during different hours?
Anything I am missing?
Thanks!
Coob
Thanks!
Coob
