Hi All,
I was wondering if I could get some opinions on a filter recommendation.
My pool is a 4ft deep, 21ft wide by 42ft long above ground pool (~24k gallons). Way too large for an ag in my opinion, especially with just the one inlet/outlet.
Current setup is a single speed 1.5hp pump, with what I believe is a 24in Hayward sand filter (can't be 100% certain as the previous owners did not place any labels, but 24in is what I measured). I just bought it last year, but in the event that I would need to replace it too, that wouldn't be a deal breaker.
The filter is physically in fairly rough shape, the threads on drain are stripped, the base it sits on is broken, and I'm fairly certain the MPV is on its last leg.
I'm considering a cartridge style filter for a few reasons, most importantly because:
1. My pool is a rather close to my septic drain field and I have had issues in the past trying to get the backwash water far enough away, so the less I have to backwash, if at all, the better.
2. I'm hoping that better filtration will aid given the fact that I have a lot of water to filter, and minimal opportunity to do so with only the one inlet/outlet.
By my best estimate, I need at a minimum a 150 square foot cartridge filter. I can only find a handful of options for AG that are that large, and they obviously are not cheap. I'm not certain what the specs are on my pump at the moment, but can get that info, but it should be in the ballpark for a large cartridge filter.
I read an article that suggested that large AG units may benefit from a larger IG filter. If that is the case, would I be able to use an IG 200 square foot cartridge filter on my AG pool? I"m not familiar with the fittings and such on an IG, but my AG is all standard 1.5" I believe.
Thoughts/Opinions?
Thanks in advance, this place is great and has helped me tremendously with my pool chemistry!
Thoughts/Opinions?
