Recommend me the best robot to clean up a lot of leaves
Apr 25, 2017
222
Greensboro, NC
Usually I love this time of year as the leaves explode with color, but then we moved to a house with a pool...and the pool is next to a heavily wooded area with lots of hardwood trees. :mad:
The leaves have started dropping and they're taking over my pool. We moved into this house in February, I opened the pool myself and it's been perfect using TFPC, and I'm about to close it soon. I figured I'd go at least one season just pulling leaves (and the local wildlife :rolleyes:) out of the pool with the net and using a manual vacuum as necessary, and it's been fine.
Now I'm curious about a robot for use in the future. Are there any good robots out there that can handle a lot of leaves? Everything from large oak leaves to smaller leaves (maybe hickory?). We also get plenty of bugs on the side of the pool with the trees (mostly spiders and beetles) and the occasional larger critter (so far this year it's been a few mice, one large rat, a very small snake, a bird, and a bird's nest).
It's a vinyl pool, grecian shape, about 18x36, 8ft deep end and a sort of beveled bottom. 1 main drain, 3 returns, 2 skimmers. Steps covered in vinyl. Liner is about 10 years old and has some wrinkles near the main drain, some wrinkles on the edges of the steps, and a few 'lips'/wrinkles spread out here and there. I've included a few photos from earlier this season since a picture is worth a thousand words.
Deep end:
Steps, and trees in the background...
Before opening in April of this year, and before I installed a fence:
I would again suggest any of the Maytronics from S200 up. They have a large basket which opens up from the top so its very easy to clean out. I would not suggest the more expensive M versions as they contain two smaller book-like filters.
Dolphin Discovery is a Maytronics from Dohaney's.
Decide if you want to purchase from a brick and mortar store or online, in case you ever need warranty work done.
Maddie :flower:
If you mean a LOT of leaves , you should keep that leaf net. This many leaves will overwhelm ANY robot. (This pic is over in Creedmoor....90 miles east of you)
https://www.google.com/url?sa=t&rct...69139-Leaves&usg=AOvVaw1NfoxN--cReyqx9I-5AQkd
Yep, that's about what my pool looks like when I don't use the net for a few days. I suppose I'll resign myself to scooping leaves....at least it's a peaceful way to wind down after a long day, and the time between "lots of leaves" and "covered for the winter" isn't too long at all.
With that being the case, it looks like I'll just need a normal pool robot that can deal with normal pool 'stuff' and not worry about having it get out all these leaves.
duraleigh -- if you own tftestkits, I ordered some stuff from you earlier today. :cool:
