- Mar 6, 2022
- 42
- Plaster
- Pentair Intellichlor IC-40
Hello we are in need of some help. Was not sure if we should post in different areas or if we can post all questions here in one spot. So here it goes:
1) We want to level the spa wall so it gives it a more continues look. The PB said that it will not spill over just run down in certain spots. Is there a way to make it run over the top more fluidly?
2) Is it worth it to put in a dedicated pool vacuum port or should we just get a robot? Will the robot accomplish the same thing?
3) We want to do 4 pentair laminars. Do we need another return or can we plumb it in to the existing equipment? We are thinking of getting another pump to run them. If we do this were would it go? Also we have an intellicenter
4) Is pool solar worth it? We are in Los Angeles CA
5) is $4500 for bubbler in new baja shelf about right? The deck will be removed down to dirt
Im sure more will come up along the way as we continue remodel.
Thank you all!
You all are the best for information so what is the best way for us to say thank you for the assistance?
Thank you all!
