- May 23, 2015
- 25,703
- Plaster
- Pentair Intellichlor IC-60
Not sure if your first question was answered, so here goes:
Welcome from another BioGuard convert!
Running some numbers in PoolMath, here's what I came up with:
16 oz. (by weight) of BurnOut 3 (57.8% cal-hypo) will:
1. Raise FC by 10 ppm, and
2. Raise CH by 7.9 ppm.
128 oz. (1 gallon) of 8.25% bleach will:
1. Raise FC by 13 ppm
128 oz. of 10% bleach will:
1. Raise FC by 16 ppm
128 oz. of 12.5% bleach will:
1. Raise FC by 20 ppm
How much do you spend (per pound) on your BurnOut? You will probably spend between $2.00 and $3.00 for a gallon of grocery store (8.25%) bleach, and can probably find 10% bleach for around $2.00 per gallon. PLUS you aren't adding to your CH when you chlorinate with bleach.
Keeping your FC levels at the appropriate level for your CYA/stabilizer will make BackUp or any other algaecide unnecessary. Keeping your other water chemistry in check with Muriatic Acid, Baking Soda, and Borax will render other BioGuard products unnecessary, as well.
Trust me, the last 3 summers I spent between $60 and $180 per weekend in the local pool store buying BioGuard products. Now I'm adding 2 quarts (1/2 gallon) of 10% liquid chlorine daily, and adjusting pH with Muriatic Acid every couple days (~24-32 oz. each time). I have to increase my Total Alkalinity just a bit with Baking Soda each weekend.
All told, it now costs me about $1.50 per day to keep my pool sparkling and, well, trouble-free. Compare that to $10+ per day using "the pool store way," and it's a considerable savings. Plus, I actually know what I'm putting in my pool and, more importantly, why I'm putting it in there.
