Hello
I want to first say this forum has been a gift for reference and knowledge for a first time pool owner. Thank you to all who contribute!
I have been fighting what I believe is algae (mustard algae?) almost all season long. I believe I introduced it into my pool. I used the same garden hose to top off my pool at the start of season that I used to pump the mucky water off the cover prior to opening. I did flush the dirty water out of the hose until it ran clear but I believe it still was contaminated?
Anyways, live and learn, this algae appears to be a goldish color and quickly powders when brushed.
I've been doing slams without a proper testing kit without any luck up until now. I just received the Tf100 kit.
Throughout the year, I would add liquid chlorine or granulated shock and find a mess of white powder on pool floor. Brush pool,, vac to waste and find a day later it would appear again. Repeat, repeat and repeated.
I would like to properly slam and test for oclt now that I have the proper kit.
Here are my current result as of today.
PH 7.8
AL 100
CL 10
FC 22
CC 0
CYA 45
On Thursday when I received the tf100 kit I tested and ran an oclt. FC dropped from 38-35. Is that evidence of algae?
Thursday evening my results were
PH 8.2
AL 140
CL 12
FC 38
CC .5
CYA 45
My questions are should I be concerned with the ph? Should I wait for fc to drop further then adjust ph if necessary? Should I just go ahead and start the slam and not worry about the ph?
I need to close the pool soon due to weather. Would it be advised to slam the pool, add polyquat 60 and hope for the best in spring? Or should I try to defeat this before closing? I have several large trees near pool waiting to drop massive leaves.
Also to mention,, there has never been a spec of algae on pool walls , is that normal?
Lastly, why is my total chlorine so much lower than fc?
Thanks!
PH 7.8
AL 100
CL 10
FC 22
CC 0
CYA 45
PH 8.2
AL 140
CL 12
FC 38
CC .5
CYA 45
Thanks!
