So I am using the Little FC PH tester from my Taylor kits for my daily testing. I have a TG100 kit too.
My main question is timing. When I use the small Taylor test for Fac and Ph the longer I hold and shake it the colors change.
Is my pool reading the exact moment I shake the chemicals into it or after letting them settle in for about 30 seconds. My reading definitely change. At first glance my FC was 4 and PH 8.2+. After 30 seconds the colors changed to FC 3 and PH 7.8.
Which is the most correct way of doing this test?
I have the same issue doing FC with the TF100. When I put the drops in to change the water color to clear if I wait a bit the water pinks back up.
Thanks.
Thanks.
