Raypak Heater Repair or Replace
ghotihook
16
Dayton, OH
I have a Raypak C-R336A-EN-X ASME heater on my 30k gallon IGP. This is a Raypak Digital 336, ASME, commercial with Cupro-Nickel Heat Exc. I've only owned the pool for 2 seasons so I don't know the age of the heater. I had a slow leak at the outlet joint at the end of the swim season and I just took it apart to repair the connection. I noticed quite a lot of corrosion in the cast iron header when I removed the outlet pipe. I've noticed similar corrosion in the cast iron return header on the opposite end of the heat exchanger. I've also seen rust flakes come out of the return jets into the pool. So obviously the headers (at least) are corroding. My question is whether it is worth it to buy replacement cast iron headers for both ends of the heat exchanger (probably ~$500+ in parts based on quick online search)? Or is it time to replace the whole heater? I'm fairly confident I could replace the headers myself with the right parts, but I'm not sure whether other parts of the heater will start to fail in the near future. Anyone have experience with repair of this heater?
I've seen a lot of Raypak heaters 5-10 years old installed in our area that appear to have a lot of rust inside the cabinet under the heater tubes and burner. If you have this I'd replace these parts as well. Exterior seems to hold up well. I don't see this as much in other brands similar age that use the coiled tube design. This is odd to me since experts here generally favor Raypak. Maybe a more recent design change? Or maybe I just happen to see more that the owner doesn't do good water balance. Or maybe its something to do with my S Florida weather. I'm not a service tech but have a lot of friends that are real estate agents and they often ask for my opinion when home inspections reveal pool equipment issues. If it were me, I'd inspect the tubes and any other parts that look like its close to failure. Then see if the cost of the parts is less than half the cost of a new heater if you're capable of repairing yourself. It probably is and if so, I'd replace it. Sounds like the prior owner may not have paid much attention to water chemistry. Keep within TFP recommendations in the future and you should get at least 5, maybe 10 years more out of it.
Chris
Attaching pictures. Overall the condition looks good to me. Not much rust other than the cast iron headers. You can see the rust inside the inlet/outlet header and the opposite side return header is rusty too. I'm leaning towards replacing the headers and calling it good. Advice?
Looks pretty good to me. I would assume the prior owner did not do a good job with water chemistry which may have damaged the headers. The question is if the heat exchanger is solid. Before you buy the new parts I would pull off the headers and see what can be seen in the heat exchanger. If it looks good then buy new headers and put it back together.
I concur with Allen. It looks better than most Raypak heaters I see in my area but I would inspect after headers are off as he recommended. I've had good experience with these people. Not always the cheapest but no the most expensive either. They are an authorized rep for many of the parts they sell.
I hope this helps.
Chris
Thanks guys, this helps a lot. Out of curiosity, what specific water chemistry imbalance would lead to the corrosion in the headers?
Low pH below 6.8.
Is there a tab chlorinator after the heater?
Reactions: setsailsoon
Was there a check valve between the heater output and the chlorinator?
The backflow of acidic water when the pump is off from the chlorinator could have damaged the heater.
I don't think there was any check valve. Either way it's gone now so hopefully replacing the cast iron headers will keep the heater going for a long time. What's the best way to connect the cast iron inlet/outlet flanges with the PVC? That joint was leaking which is what started my investigation into the heater to begin with.
For the connection I would order a set of flange connectors. They usually come with gaskets and the flange nuts. You can find them online for $30-$50. CMP makes an after market version that is a little less expensive for most heaters.
Chris
