Rain washed mud and tree trimmings into pool
Mcas
Active member
Jun 24, 2018
32
Sacramento ca
Massive rain storm washed mud, tree removal trimmings (bark, sawdust, pine needles), and dirt into pool destroying my salt water pool chemistry. I am running my filter on high rpm 24/7, I have cleaned filters twice now, running robot cleaner (polaris Alpha IQ+) for 30 mins at a time as that is when the filter basket is 100% full.
I rebalanced pool this AM after testing as I needed to address FC, TA, Salinity. I am keeping FC high (added 12.5% chlorine) to prevent any algae growth due to the mud/tree trimmings. I am running SWG on 100% boost. Looking to keep FC about 8ppm. Before the pool got destroyed CYA was 80, I have not tested yet but assume its way lower due to the washout.
As can be expected, the pool water is completely brown, saw maybe a 5% increase in visibility over night.
What else should I be doing here to address the pool? Any chemicals I should proactively be adding here outside of normal pool chems?
Thanks
It seems like you are doing everything correctly, maybe a few tweaks:
- Do you have a net where you can try to blindly scoop debris off the bottom. If your robot is filling up after 30 mins there is quite a bit down there and scooping out manually will help speed along the process.
- 8FC is good, but only slightly over your target FC of 6. I would bump it up to 10-15, and you could even take it up to SLAM level which is 31.
Thank you for your reply. I do agree I will bump up FC a ton, I have the SWG on 100% but will throw in liquid chlorine to get to a much higher FC sooner. And yes I do have a net and tried it a few times, was unsuccessful but will keep trying, I think I might have to get into the pool to be more effective.
