Hello All.
This is our first pool.. we spoke with 4 PBs and have narrowed with one.
I asked for a Freeform pool with a spa around 110 sq ft.
The PB offers transformable guarantee on the sheel of the pool. We are thinking of Salt pool.
PB is saying VS pumps will be additional but was saying the it won't be too much of a savings.
General
Pool/spa Perimeter 117’
Pool/spa area 539sqft.
Pool Size 35’ x 23.3’
Pool Depth 3’6”- 3’9”- 5’6”
Pool Tile - Standard pool tile at waterline
Pool Edge - Flagstone coping
Pool Structures
Raised Spa 12’’ with stacked flagstone spillway
Sun deck with 2 bubblers
7 Ton Natural Rock Waterfall
Decking -
Install approx. 839sqft. Concrete
Spray Deck 1269sqft. (Color of customer’s choice)
Pool Steel
4 - #4 rebar full 12’’ box beam
#3 rebar @ 8” O.C. in all areas
Plumbing
Install two gunite skimmers per plan
Install six return inlets
Install one dedicated Polaris cleaner line per plan
Install two main drains
Install one 2 hp circulation pump (Hayward TriStar)
Install one 2 hp water feature pump (Hayward TriStar)
Install one .75 hp cleaner pump (Hayward)
Install one 425sqft. cartridge filter (Hayward)
Gunite
Spray gunite to shell, raised beams, ledge, benches, and equipment pad
Trim all features, benches, steps, etc. per approved plan
Put all rebound in pad or ramp
Electric
Install and hook up one PS8 Controller with wireless aqua pod
Install and hook up one circulation pump
Install and hook up one waterfall pump
Install and hook up one Polaris booster pump
Install and hook up GFCI
Install and hook up 1 LED pool & 1 LED Spa light
Bond pool as required
Tile Coping
Provide and install multi blend Flagstone coping
Provide and install waterline tile per approved plan
Decking
Install 839 sqft. concrete per plan
Spray Deck 1269 sqft. (Color of customer’s choice)
Clean up
Clean up after gunite and new decking is poured
Equipment
1-425 cartridge filter
1- 2 hp circulation pump
1- 2 hp waterfall pump
1 -.75 Polaris cleaner pump
1-Chlorinator
2- Skimmers
2- Light niches
1-Pool lights
1-Spa Light
1-PS8 Controller with wireless aqua pod
1-280 Polaris cleaner
3-3 way Jandy valves
3-2 way Jandy valves
1-Spring check valve
1-1 hp Blower for Spa
1-400,000BTU Heater
Pole, net and brush
Interior
Quartz (Gemstone) 7yr warranty
Start up / Pool school
Start up all equipment
Adjust valves
Mastic installed
Instruct homeowner in use of pool
Not covered:
Fence; sprinklers; landscaping; grass sod; any utility reroutes or upgrade of service; or anything not included on improved plan.
Pool & Spa Price
$51,125.00
Pebble (15 year warranty) Option
$2,000.00
Salt Option
$1,200.00
General
Pool Structures
Decking -
Pool Steel
Plumbing
Gunite
Electric
Tile Coping
Decking
Clean up
Equipment
1-Chlorinator
2- Skimmers
2- Light niches
1-Pool lights
1-Spa Light
1-400,000BTU Heater
Pole, net and brush
Interior
Adjust valves
Mastic installed
Not covered:
Pool & Spa Price
$51,125.00
$2,000.00
Salt Option
$1,200.00
