Hi!
I maintain 2 private indoor spas. Thanks to TFP, I have been able to test the water and maintain safe sanitizer levels. We also solved our cloudiness issues.
The filter runs about 12 hours/day, in 2 sessions. I realize the aeration from the filter might effect pH.
got my TA up to ~90
pH keeps spiking to 8.2 (or higher?)
Is it normal to be adding acid a few times a week?
Can I ignore TA (let them fall at 40-50), if my pH is in the normal range? I just watched the TFP video on the lower TA recommendation. Does that apply to bromine pucks also?
I learned here that MPS messes with my dpd readings, so I’ve been using liquid bleach as a shock a lot. Would prefer to use MPS.
Any way to calculate the effect, either in level or duration? Is it worth it to get the MPS interference remover vs just using bleach
The hardness is very low (75, 100) on both. Can I use the hardness increasing stuff on the same day as other chemicals?
Thanks so much!
got my TA up to ~90
Thanks so much!
