Hello,
I purchased
Automatic Suction Vacuum-generic Climb Wall Pool Cleaner Sweeper In-Ground Suction Side + Hose Set XtremepowerUS and have had it situated where it's attached to skimmer for the past 2 years.
I never realized, but my main drain is not suctioning. Reason I realized this is due to myself doing the pool work where shock granules on the bottom of the pool appears to be sitting on the ground.
So when I attach sweeper to the skimmer, I am afraid my only flow to my pool is now being relegated to the sweeper flow.
I did a little bit of research on main pool on and off, but my house doesn't have such a thing and it maybe one that feeds off the skimmer (?) but even when the sweeper is not attached to skimmer, I still see granules stuck on the bottom
So I am hoping you can help me to find if the "white" pipe that is on the side of the pool wall that has some knob is to be used for sweeper suction (attached picture)
thank you so much
I purchased
thank you so much
