I'm sure there will be differing opinions on this so heres the question. Our pool has a 350000 BTU propane heater. It will bring the temp up about 2-3 degrees per hour when fired up. I'm racking my brain over should I set and hold the temps at my desired temps (mid 80's) or turn the temp down (mid 70's) while not in use. Case in point, we will not be in the pool at all for the next 5-7 days (just looking at the forecast) Would I be better off turning the temp down a few degrees until warmer weather returns? What do others do? Thanks for any help!
