I'm currently doing an owner build, and wanted to build a fire table. It's been something I've planned to take on as a DIY project. Let me explain:
On the upper portion of the deck(behind the pool, 1' from the edge), I want to build a 12" high table that spans across the top of the deck 20 feet, almost all the way to the spa.
On this table, I want 4 fire pits directly above the water spillway scuppers. The pits will be 12x6 inches (same width as the scuppers). Something like this
Do any of you have a good recommendation of what to use for a pan to hold the burner and glass?
Here's my diagram:
On the east side of the deck there is a 1.5" gas stubbed out for this.
Few questions. What kind of pipe can be used for this outdoor setup? Is Stainless steel a must?
Another question: Where should I reduce the 1.5" down for best results?
I planned to plumb this myself, can anyone help me with a diagram how I should best run this?
I appreciate any help or advice you might have, or suggestions on what you would do differently.
Thanks, Nick in Socal
Here's my diagram:
