plan to hook up my air compressor to the drain plug on my pump to blow air to clear pipes for closing my pool.
My question is this.
On the suction side, I have 1 skimmer, and 1 drain. My jandy valve allows me to either have the Skimmer on/drain off, drain on/skimmer off, or both ON.
I do not have an option to close both at the same time.
So I’m wondering how I will ensure that I am blowing air into the return side only. My thinking is that even if I air lock the drain, and gizmo the skimmer, that the PSI might be too much and instead of blowing air only through the return side, I will blow out the gizmo. Am I thinking correctly, or should I be worried about that?
