This is about my third year using the TFP method of sanitizing pool water and I have a question.
I've kept notes of my test results and each year I have had a similar experience each year. The pool opens with fairly clean water. I manually scoop out the dead worms from the bottom and run an Aquabot and hand skimmer net to remove the rest of the silt and debris. I start the system with a slam that takes weeks to get to a point that the free chlorine becomes stable for any length of time. I am using one to two gallons of chlorine/day and this keeps up for a couple of weeks when the water will finally hold a steady chlorine level and pass the OCLT.
This year I started the slam at 30ppm CYA and was maintaining a 16ppm FC level. Now I am at 50ppm CYA and maintaining a 20ppm FC level. I am adding a gallon or two od 12.5% chlorine per day to maintain the shock level. The pool is 16x32 inground and approx 18000 gallons of water.
The only thing that I can think is going on is that there is a lot of new bad stuff getting into the water. The pollen is terrible here in Connecticut right now and the pool is near a bunch of white pine trees and forsythia bushes. The water has been clear from a couple of days into the process. I did sadly find a chipmunk in the skimmer a few days ago that knocked the chlorine down by a bunch but I caught it quickly.
My question is whether anyone else here has taken so long to clean up the water on opening? Any ideas are welcome. After three years I still don't know what I can do differently. The water does eventually clean up but it takes a very long time and a lot of chlorine.
Mike.
Mike.
