Hello,
We have a pool that is older, it doesn't have flat coping but rather giant pavers and the seal is on the vertical walls - of course the pavers have moved a bit since the 70's but the previous owner did have the liner redone so that's in good shape.
Some of the seams have developed gaps due to the pavers moving. I understand that the best thing to do would be to pull them up completely and re-flat everything, but for a "few years solution" what would you recommend to seal above the tile line, but below the pavers? It looks like someone did caulking at some point and it's in good shape, but the mastic seal below that, above the pavers, has deteriorated, as it's probably original. Should I try to use more soft sealant like sika flex, or some kind of concrete / mastic? Bear in mind, The Gap is so pronounced because I dug this one out as my test paver most of them are not this bad it would just be three or four out of about 20 of them.
Thanks for any advice,
Dave
Dave
