- Mar 31, 2022
- 77
- Fiberglass
- Pentair Intellichlor IC-20
I have an automatic valve actuator controlling a valve that diverts suction water from the pool to the spa. When I close the pool for the season, I need to airlock the spa's main suction line. With a manual valve I can close it quickly to air lock it. But since this valve has a electronic actuator, the movement of the valve is very slow. I can continue to blow air into the line as the valve is actuating, but as the opening get smaller will the airflow be enough to keep the water out of the line until the valve is completely closed? Keep in mind, I have a cyclone blower for the job.
Mark McLeroy
Mark McLeroy
