Looking to get into using a swg with the increase in price in bleach.
Right now after the filter on my waterway Clearwater II runs a short (5 inches) pvc to the garbage that is my pool store installed pool frog which has a short pvc cutoff after it that connects to hose going to my return.
I would like to cut off the pool frog that I haven't used since the first season and put the plate section of the swg there instead.
What kind of support do these usually need? The pool frog sits on a small black plastic stand that came with the whole deal. And past that there is no support for the cutoff and the hose drops a couple inches to the ground before going off to my pools return.
My concern is if I attach the SWG run and put the cutoff after it that the weight of the cutoff and hose would put too much strain on the swg plate module. What is the best way to support it so it isn't just hanging off the filter before the hose?
Anyone else using a swg with a hose run? Not quite interested in doing a complete PVC run to the pool.
Edit: added picture.
