Purchasing a home/pool- Converting to TFP method
geldry
3
Louisiana
Hi pool gurus,
I am purchasing a home with a pool at the end of this week. I'm a first time pool owner, but I've been absorbing as much as I can here and am ready to hit the ground running with the TFP method. The pool is 32,000 gal gunite/plaster.
I bought a TF-Pro test kit and was able to grab a sample of water while doing my final home walkthrough yesterday so that I know what I'm facing once I take over. The current owner uses chlorine tablets in the skimmer basket and said they also throw 1 lb of cal-hypo shock in every week. They're clearly not a TFP reader. The water looks blue/clear, but i did notice some isolated green algae growth on the walls.
Here are my test results from the TF-Pro. I'm facing several issues and would love guidance on an order of operations to bring everything in line.
CYA: 90ppm (darn tablets)
FC: 22.5 ppm
CC: 0 ppm
TC: 22.5 ppm
pH: 7.3
TA: 60 ppm
Ca: 225 ppm
Temp: 83 F
CSI: -0.740 (concerning for a plaster pool)
I was surprised to see the FC so high given the visible algae, but maybe the current owner was trying to nuke it before my walkthrough.
I see this as 3 separate problems: CYA, Algae, CSI, and I would love opinions on which to tackle first. I know the CYA will require that I drain and refill about half of the pool to bring it into range, so I'm inclined to do that first so that I don't add a bunch of chemicals just to drain half of them away. After that, I would re-test everything and maybe dump in some Calcium chloride to get the CSI up closer to neutral. Then SLAM for algae, and do final adjustments on pH/TA/Ca once complete.
How would you experts go about course correcting from the current state? How worried should I be about this very negative CSI? The pool was resurfaced about 4 years ago, but I know this can do harm to the plaster in the long term.
Welcome to TFP.
Install a SWG ASAP and then your CYA is almost perfect.
Stop using the Trichlor tablets and the pH will naturally rise to around 7.8 to 8. That will naturally fix rhe CSI.
Once you take possession, follow the SLAM Process to clear the algae.
You are in better shape than you think.
Post some pictures of the pool and equipment when you can.
You have PoolMath?
Reactions: ringi
Welcome to TFP.
You have PoolMath?
This is a great suggestion. I hadn’t much looked at the target ranges for SWG pools because I was thinking more in terms of managing the pool as is.
SWG conversion is on my radar, but unfortunately not an immediate option due to the many other projects, improvements, and expenses already coming with the new home.
You might want to check if those Xtra Blue tablets have copper in them. Blue is usually a code word for copper.
If so you may want to consider a drain and refill before you get copper staining.
