Pumping to Waste below the skimmers
Scubaduba
2
Massachusetts, usa
Using an older Standard Hayward DE filter (60 sq ft). It only has the Down/up, push pull waste drain valve.
Q1. If I Drain to Waste for an extended period (say an hour or two) in order to drain down my pool a significant amount, will this possibly cause any damage to the filter element Grids?
Q2. If I drain below the skimmers using the "Drain to waste" method, is it safe to just shut off the return line to the skimmers at the pump, and direct it 100% to the main drains? I also have a spa, I guess I would need to isolate these floor returns also?
You should use a submersible pump to drain your pool below the skimmers.
Many main drains alone cannot provide the water flow a pump needs. And some main drains hardly work at all.
Don’t put your expensive pool pump at risk for damage by running dry.
Why do you need to drain?
